Ball
- 0
- 1
- Oakridge, OR
Can anybody confirm if a 96+ model Chevy NV4500 will work in a '85 CUCV? The ratios on the older model NV4500 (compared to the 92-95) look better for 4.56 axles.
you can, but usually it requires running a really long line under the bellhousing over to the passenger side where the bump on the bell is huge and usually interferes with the passenger side exhaust/starter/ and front driveshaft.I might have to make a trip to Devil's Tower and do some rock climbing while mulling the situation over.
Why can't one keep the slave cylinder where it is?
The stock 6.5 GMT400 6.5TD NV4500 bellhousing works fine. I have the earlier external slave on mine and it works fine and Dstang97 just did a 96+ internal with no modifications save the custom hydraulic line. If your cab is 85+ It will even have the imprints where the master goes. use 85-87 Master with whatever slave you choose(internal or external. BTW the AA bellhousing will NOT work on a 6.2 because the starter AFAIK is too long and will hit. I know the gasser bellhousings won't work with a diesel so i would assume the AA one has the same issue. There was a write up on this conversion in an old issue of 4 wheeler where the morons actually cut a triangle out of the bellhousing where the starter nose hit rather than do thier homework and just use an NV diesel GMT400 bellhousing.Yup it will work,,,, biggest thing is bellhousing and transfer case. the bell will have the issue of hydro clutch or manual... Manual will take some creation to mount a linkage. the hydro will need to be moved outside of the bellhousing with a bracket.. I suggest getting AA's bracket and cutting it up and rewelding it in a config that is more usable. The stock bell for the NV4500 puts the slave on the passenger side thus no good here. the aftermarket ones have it on the driver side (AA again) but thats about $400...... You can find one of the old SM465 bells and bore out the center hole, this has been done too.... The 4500 clutch is a fairly simple 12" GM truck clutch but make sure you have the one for diesel or the center will eventually blow out... also find the solid flywheel, (gives less trouble than the dualmass.
The other end,,,,,, the output can be touchy,,,,, You will need to find a NP205 from off a TH400. this will have the 27 or 29(cant remember) spline output with a 6 bolt round pattern. The NP208 off a later SM465 will be the same but its a lighter T case and chain drive,,,, easier shifts but weaker and not twin stick adaptable. ( I have both laying in my shop floor, 1 for the Willys, and 1 for the 65 GMC)
Note on earlier GM 4500s..... Pre 95 ran a proprietary bellhousing to trans bolt pattern that is hard to find a correct bell for.... post 95 GM and Dodge ran the same bell to trans pattern opening up the world to swapping the input shaft from dodge to GM or vice versa.
Pre 95 GM also ran the super low 6: ?? to 1 first gear (called "L" on the shifter) but the OD was the same as all other models GM or Dodge. Post 95 GM did away with the super low and went with the 5: ?? like Dodge.
Confused yet.....?????? If you need to call me,,, I have all of the above laying in the floor,,,measurements/spline counts etc
J. Stiver 307-282-0773
Yes, the 208 case although never mated to an NV from the factory, fits like it was made for it. The bolt pattern is an exact 180 mirror.Oh, and the m1010 would have a mp208 stock and should bolt right in, as I understand it.
Were there any issues using the gasser bell housing?I'm running a 1996 nv4500 bell housing, tranny and slave out of a gasser.
86+ oem master cylinder
86+ pedals
86+ np205
advanced adapter 2" spacer for the transfercase.
If I was to do it again I would have used the factory 208
Running a oem starter
Quote in yellow, my answers in gray text.The stock 6.5 GMT400 6.5TD NV4500 bellhousing works fine. (if you can find one without going to the stealership)
True
I ran a gear reduction starter that didnt have a nose cone,,, fit nicely,,,, the first starter I had (6.5 starter) did contact some but we selectivly ground the inside cup of the nose hole and it was fine,,, btw this was a gasser bellhousing.....
Don't forget you will have to fab a valley drain tube.
What is this,???? turbo return drain???
No mods to the bell housing. Needed to grind my starter slightly. Only hard job was the custom hydraulic line I had to fab up. My cab is a 84 so I had to use a template to cut the holes in the cab.Were there any issues using the gasser bell housing?
You're making this sound too easy![]()
