Trailer to haul a M1008
WhiskeyDelta
Florida
Anyone near Fort Walton FL. have a trailer capable of hauling a m1008?
Just purchased mine in north Georgia and want to get it home Friday.
All the rental companies have turned me down either because of weight or the fact I'm driving out of state.
Any other options for getting it home?
Recovry4x4
LLM/Member 785
1,823
GA Mountains
Have you considered a tow bar? It will require decent tires on the CUCV. How far north in GA?
4x4 Forever
Emerald Shellback
The weight or the towing vehicle? Many times they will not rent unless you have a big enough truck, i.e.. 3/4 or 1ton.
Get the largest U-haul trailer and the M1008 will fit with 4-6 inches to spare, I would double strap it on the front and back axles.
I recovered my M1008 this way and all was AOK, double strap it.
Good Luck!
4x4 Forever
Emerald Shellback
Can you get your M1008 weighed? If I remember correctly, mine came to just under 5200# and the trailers are rated for 5290#.
Also, remember that their largest trailers are not everywhere, I had to put an order in for one several days before I needed it.
If you do not feel comfortable with trailering, go with Recovery4x4 suggestion in using a tow bar.
Recovry4x4
LLM/Member 785
1,823
GA Mountains
I have thousands of miles towing CUCVs between 55-60. They are very friendly to the flat tow. Need to unlock hubs and steering wheel lock. I prefer to remove rear axle shafts, others do not. Since I have block off plates and an impact, it's a 5 minute job and I don't have to lay under the truck. How far north in GA are you going?
UNIMOG-GUY
33
Blacksburg, VA/Denver, CO
I have also towed several CUCV's long distances and would recommend that you remove the rear driveshaft as well. Also make sure you have some safety chains hooked up like in AMGeneral's pics. And don't forget the tow lights to put on the CUCV's back bumper/tailgate/bedsides. There are numerous threads on tow baring a CUCV on this site be sure to read them before you go.
Chevybrit
Northern Pasquotank NC
"Since I have block off plates and an impact, it's a 5 minute job and I don't have to lay under the truck."
An old thread I know but i wondered if someone could explain what these are?? (obviously not the impact)
Evil Dr. Porkchop
316
Colchester, VT
I'm guessing those are covers to bolt on in place of the rear axle shafts.
truck1
10
San Anselmo,CA.
Block off plates are used to cover the axle tubes in the differential housing so no oil leaks out. Some people use cut axle stubs or make steel plate the same dimensions and bolt hole placement as the axles.
