M925 Winch Not Going In
3poffroad
Cypress, tx
Hey guys! Finally got my new M925 Home yesterday and spent all day going through and changing fluids and cleaning ect. The PTO Will engage and once i put the transmisison in N the winch will run "out" with the lever but will not run "in" The lever seems very stiff and stuck.
Any Pointers?
Scar59
42
Mt. Eden, KY
Crawl under the truck and follow the selector cable to the selector valve, lube an adjustment most likely needed. Disconnect the cable and lube it also. Operate the winch from the selector valve to trouble shoot. Have a "soldier B" w/ you for over watch.
3poffroad
Cypress, tx
Got up under it and removed the arm, lubed it up and lubed the cable up. Works great now! Thank you for the input! You guys are the bomb!
