Lmtv m1081
FloridaAKM
395
Gainesville, Florida
What is the finned connection under the hydraulic cab lock that the alternator cable leads go to & the cables come from the battery? There are several posts that the leads are all bolted to. The reason I ask is that the truck I have had the 24v lead come loose @ some time & it wore the threads off to where you could not tighten the leads back up! I have not found it in the TM's either!
FloridaAKM
395
That is it! I found a picture of it, but no explanation as to what it does! The top threaded post broke off while trying to remove the nut since it wouldn't tighten down!
FloridaAKM
395
I fixed the issue with the broken post, now there is the matter of electrically testing the unit to make sure it is working as designed! Seems like the Army mechanics liked to take stuff apart, but not put it back together on this truck!
Lmtv772
Banned
651
Florida
That's how they usually do it and I am thankful for it. It shows the next person handling the truck what was done before and what was taken off. You are supposed to do your PMCS anyway, so you'd find all the lose ends :)
FloridaAKM
395
While I am @ it, can you get the brake caging bolts & nuts @ NAPA. Seems some soldier needed them more for another issue than me & took all 4 bolts & nuts off the rear axel & kept them before turning in the truck!
Answer: Yes, NAPA has the caging tools (bolts) for $6.00 each..........10 minimum purchase!!!!
FloridaAKM
395
Okay, tested the charging system after the repair to the reverse polarity relay. All is good & the system is charging as designed. Now back to the air leaks....
FloridaAKM
395
NAPA shows no availability of the valves or repair kits on any of the air brake systems made by Haldex for these trucks. What is plan "B" for those of us with air brake problems with these valves?
