Best way to wire up a RAK15 ration heater?
B3.3T
86
SW Ohio
Looking to wire up a RAK15 ration heater from scratch. Draws 24vdc 15 amps. 10 gauge directly from the batteries with 20 amp. inline fuse?
Recovry4x4
LLM/Member 785
1,814
GA Mountains
I have mine on a 50A Anderson plug with a 50-175A adapter to plug it into the Pt compartment of the ambulance. I need to add 50A pugs to the other trucks.
Storm 51
Just a Grunt
9
Seattle, WA
According to my aircraft spec sheet (24-28VDC) 12 or 14 gauge should be just fine. The stock military cord for it is 14/2 (2 ea 24 ga wire).
Mine is hooked up with the stock military plug (3 prong female 12-14 gauge) and it works great.
Get the manual (it's online) and it will show you everything you need to know.
They are actually very well built simple little heaters.
I need to get one more.....
B3.3T
86
SW Ohio
Thanks, guys. There were a ton of the newer 471012 models at Findlay, new in the box with manuals.
Storm 51
Just a Grunt
9
Seattle, WA
The newer ones (RAK-30) are 30 Amp units, I believe. That's more than my little truck can generate.
If you find a bunch of RAK-15's, I would sure appreciate knowing about it.
jpg
13
boston
I bought the connectors on line. The wire at Home Depot. I used outdoor rated wire, of the max gauge called for by the connector spec.
Mine is the 15A model. It cooks well, using Sous-vide recipies.
jpg
13
boston
Thanks, that thing has been elusive to me.
Any time. FYI, I found it by reading the M1010 TMs. I got the part number for the female socket from there, looked the manufacturer up on line, and on their web site I found the compatible male. Once I had the part identified, I went shopping and found Amazon had the best price at the time.
For parts that are still in production, the TMs and Google are your friends. For parts out of production, I've found what I needed on SS & Flea Bay.
MWMULES
344
DESOTO, KANSAS
The older field surgical light and other old school medical equipment use/ used that plug.
surgl1.jpg surgl2.jpe
Recovry4x4
LLM/Member 785
1,814
GA Mountains
I tried to look backwards from the number on the socket and failed. Dang, shoulda had a V8/TM.
M813rc
2,717
Near Austin, Texas
Just FYI, the plug on the heater end of the chord is the same as that used for the M35/M813/M-etc. turn signal flasher.
Cheers
jpg
13
boston
Cheers
And here is a current commercial source for the heater end:
http://www.newark.com/amphenol-industrial/ms3106f16-10s/circular-connector-plug-size-16/dp/85C4054
newark.com Got a question? Give us a call. (800) 463-9275.
Stock No:Manufacturer Part No:UOM:Quantity:Price:Extended Price:
85C4054MS3106F16-10SEach 11$21.81$21.81
Description: CIRCULAR CONNECTOR PLUG, SIZE 16, 3 POSITION, CABLE; Military Specification:MIL-DTL-5015 Series; Circular Connector Shell Style:Straight Plug; No. of Contacts:3; Circular Contact Type:Solder Socket; Coupling Style:Threaded
AttackMule
KC MO
I contacted Bibby Scientific, who owns the company that made the heaters (Electrothermal). They put me in touch with folks at Cole-Parmer. They provide support for the product here in US. There are dozens of these things available in military supply system but no complete cables--so i am going to modify one.
The RAK-15 info shows unit plug is Amphenol MS3102R-16-10P (pin A is 24VDC, pin B is 0 volts and C is not connected) and two socket part numbers. One is a straight socket (MS3106R-16-10S) as listed by jpg the other is a 90 (MS3108R-16-10S). I ordered the 90 for $50. Also, the lit says to use cable clamp bushing MS3057-8A on sockets. I will post an update and picture.
Storm 51
Just a Grunt
9
Seattle, WA
JPG is correct about current availability. These are very common plugs and easily available from many different sources.
My preferred source is American Component Supply [FONT=&quot][/FONT][FONT=&quot][/FONT][FONT=&quot][/FONT][FONT=&quot]in Greenville, SC.
I use a 90 degree plug on my unit because it is mounted in the bed on the side of my truck.
[/FONT]
Rusty Loads
Ontario, Canada
Dragging up the dead thread here... I looked at RAK manuals online and could not find which of the 3 pins carry the 24V and or ground. Per notes above the hot wire is "A" and...The 0 value pin you mention above (B) I am assuming that means ground? Thanks for any help on these-I may just call Cole-Parmer in Canada. I have a RAK-15/4 coming from OZ which has the boil feature which I think would be handy. Thanks for any help.
