Deuce compression test acceptable PSI
SCSG-G4
PSVB 3003
5,401
3,499
Lexington, South Carolina
Since it's supposed to be 22:1, I would thing anything over 310 psi would be in the ballpark. If it's lower it may not have enough compression to heat the air up for reliable ignition.2cents
frank8003
4,990
Ft. Lauderdale, Florida
jatonka
111
Ephratah, New York
Thank you all for your help. I did the test on a cold engine and my pressures came out low but quite even across all 6 cylinders. I got 230-240 PSI. I will get the truck warmed up well and try it again. John T
gimpyrobb
dumpsterlandingfromorbit!
27,791
788
Cincy Ohio
Frank, if you keep reading past your highlighted section, it explains some pistons are 20:1 and will have the 500-550 psi reading.
rustystud
3,392
Woodinville, Washington
I'm probably guilty of that myself as I just posted the first one I read. Your correct about the compression ratios and PSI readings. In the later Depot TM it mentioned the LDS as being 600 to 650 PSI with the 22:1 compression ratio and I would assume that would also apply to the LDT with 22:1 ratio also.
