wadefreedomvehicles
- 6
- 18
- Orem, Utah
That's a good looking job.Got all my other parts painted!
Where you taking it to if I may ask?All but three punch list items are completed, one of those being to touch up the paint / paint screws, nuts, bolts, etc. which will have to happen when it warms up. We are taking it to the mechanic for the timing to be set - totally out of my league there - and get the carburetor adjusted.
View attachment 658181View attachment 658182
It goes faster than you think and it's fun. Paint looks great, too. Good job!Now to the tedious assembly process...
I am way out of my depth when it comes to tackling the dual calibration of timing and carburetor. I think I could do the carburetor but I just don't understand enough about the timing process to do it myself. I replaced a 12 volt system (hack job) which included replacing the distributor. This is the only that I have farmed out.Where you taking it to if I may ask?
WAHOO! You guys rock!Bravo, your jeep runs.
Awesome! I am impressed that you are going with copper for your vacuum lines. Very nice touch.Got my engine running, then i discovered my radiator took a bashing while in storage.. Two leaks and not holding water well, big bumber. Also found couple oil leaks and burned my hand on the hot oil, hope got those fixed. Got all my fording system together and attached, except the line that run from transfer to pump, had bought wrong size copper lines.
