Augdog1964
- 17
- 18
- Richmond, IN
Has anyone ever seen a turret / weapon's station, installed in a helmet hardtop?
Was that mean't to be helpful, or sarcastic?With nuts and bolts.
That is the standard Old School Turret Support setup that was used on Weapons Carriers ect. That is not nearly high enough to be able to be used for the Helmet Tops. It is normally up tight against the bottom of the roof panel. The Helmet tops are about six or more inches higher than an Old School Slant Back roof panel so you would have to make some sort of adaptor to extend up towards the Helmet top roof and then support the Turret Bearing. Just raising the Turret support up may be problematic as the forward legs will probably hit the front curved portion of the Helmet Top and you will have to make up new connectors up front, for the B Pillar connections and for the C Beam connections too.Was that mean't to be helpful, or sarcastic?
If helpful, does that mean the ring simply mounts via bolts on either side of the hardtop?
