Opened drain and it stalled out
tokarev
Safety Harbor Florida
Fuel filter drain - Today I tried opening the valve (first time) while the engine was idling and the engine stumbled and stalled out. I was under the impression that during idle was the the time to drain water from the filter. Now she dont want to start up - Theres a slight chance its out of fuel - fuel gauge has been relatively accurate. 10 gallons will be added tonight........
TOBASH
3,851
Brooklyn, NY
Jericho
70
Landaff NH
I have started M 35s with ether on more than a few occurences BUT the method he is talking about above is SO MUCH BETTER .
TOBASH
3,851
Brooklyn, NY
it is also possible that when you opened the valve you allowed to air into the unit. not likely but possible.
tokarev
I was thinking the same on letting air in the system....but thats how your supposed drain water from the filter. Truck started and was running fine before I opened the valve. Tomorrow we check fuel pump
Retiredwarhorses
4,464
Brentwood, Calif
YOur fuel pump is bad, I had this same issue on a truck. The injector pump was drawing from the fuel tank, not the pump.
when you opened the water separator drain, you lost suction. This happened to me on a hmmwv while on duty and was During a joint inspection, the army showed up with full fuel tanks.....hmmwv was going on a C17 ride, AFI requires that there only be a 1/4 tank of fuel for flight....anyway, bad fuel pump.
tokarev
I am sure this has been asked before - Is the fuel pump for a 6.5 civilian the same as the 6.5 non turbo M998 engine ( engine was replaced in 07) ?
Retiredwarhorses
4,464
Brentwood, Calif
Yes...but make sure it has the vent nipple on it, any model year 1980's 6.2 equipped trucks that had the 6.2 or 6.5.
chevy, GM...CK pickups, suburbans....
Retiredwarhorses
4,464
Brentwood, Calif
and then again....may want to make sure you have fuel first.
kc5mzd
Texas
If you have a working in tank pump to drain the water. You should shut the engine off and turn the start switch to the run position without starting the engine. Then with the in tank pump running open the valve on the water separator part way till clean fuel comes out. Then close it. Turn the start switch to off. Then start and run normally.
With no or broken in tank pump you should fill the tank all the way up. WITH THE ENGINE OFF - Make sure the fuel level in the tank is several inches higher than the water separator. Then slowly open the valve with your finger over the drain. If you feel suction close the valve immediately. If liquid comes out - allow to drain till clean fuel comes out then close the valve. Then you should be able to start and run normally till you can fix the in tank pump if it is broken.
I don't care what anyone says If you breach the fuel system with the engine running you run the risk of allowing air into the system and disabling the vehicle.
dmetalmiki
2,033
London England
"I don't care what anyone says If you breach the fuel system with the engine running you run the risk of allowing air into the system and disabling the vehicle."
Yep! best way is engine off. Then as said, Switch on, and the in tank (should) do the rest.I that pump is not working, (You ought to be able to hear it running) The other methods mentioned can be tried.
Retiredwarhorses
4,464
Brentwood, Calif
There is no in tank fuel pump on a hmmwv, the water separator drain Petcock is opened while at idle, the fuel pressure forces out water and debris at the bottom of the fuel filter canister. The fuel pressure pushes out any air, it does not suck it back in, but in the case of a bad fuel pump...then there is no pressure and that can allow air to enter in and starve the motor of fuel once the injector pump losses suction.
LouWon
103
Michigan
Just did new glow plugs and injectors and fuel filter, got the same exact issue, it was idling rough, so I opened the drain and it stopped, I refilled the fuel filter and it ran like crap, It limped into the garage, I refilled the the filter assembly but it would not restart.
I cranked the engine, still no fuel coming out of the filter, disconnected the filter and still no fuel from the pump outlet.
This is not the best to do , but I filtered some fuel and hooked a hose to the injector pump and the engine started and ran fine, but no fuel came out of the pump outlet.
New pump is on order and I took the old one off and cut it open the diaphragm is ok, but the pump was sticking, see picture IMG_1501 (1).JPG
LouWon
103
Michigan
Quick update, got the new pump, put a drain hose on the fuel filter outlet, cranked the engine until there were no bubbles.
Re hooked the hose to the injector pump and it runs like new
