M116A3 Trailer, HMMWV Command Shelter & Rooftop Tent camper build…
moe1234
Wesley Chapel, FL
M116A3 Trailer Prep part 4 painted the TRL deck
This past weekend I painted the trailer deck to make it blend and make it easier to paintthe trailer after I get the command box mounted and you can see my supervisorhanging out under the trailer while I was doing all the work….
RjSteed
Wesley Chapel, Fl
Well, at least the paint worked... I was wondering since it had sat around so long...
Looking good so far...
We need to work on your spray painting skills though... :grin:
If you wanted to spend more time with the painting of it that is....
moe1234
Wesley Chapel, FL
M116A3 Trailer Prep part 5 Surge Brakes Problems
Well I wanted to do a PMCS on the surge brakes before I mount the command box. Been hearing some banging while pull the trailer and did not give it much thought due to the landing leg. While I was wrong….
First you can move the lunette back and forth a bit and master cylinder was empty and rusty.
So for the **** of it…. Filled up the master and tried to bleed the system… oh yea a NO GO at this station lol, but what the ****.
Pulled off the master, cleaned and did a bench test to find out the valve was taken in air when you worked the plunger.
Found a new 10614 hydro-act actuator master cylinder for $102.95
https://www.crofttrailer.com/10614-hydro-act-actuator-master-cylinder/#page=page-1
they also have a marine version to for $130.95 and not sure which I’m going to get.
Also have a parking brake line rubbing against the tire I need to fix as well.
Tinstar
2,562
East of Edmond, Oklahoma
I would have checked brake fluid and brakes first day.
Hopefully you already checked the wheel bearings/races.
With your master cylinder looking like that, you will need to replace the wheel brake cylinders.
Don't forget to clean the line out also.
Once you have it all done, the surge brakes are great!
Evil Dr. Porkchop
339
Colchester, VT
The same master cylinder is used in other applications so you can find them cheaper than $100 if you shop around. I can't recall the part number off hand but there is a post about it here on the forum.
moe1234
Wesley Chapel, FL
yea hindsight is a mother.... I got 2 of M116A3 gen trailers about 3 years ago for future builds or parts.... definitely will check the brake cylinders on all my trailers
moe1234
Wesley Chapel, FL
M116A3 Trailer test mount of command box
Been busy with other project (bathroom remodel) , but got around to try and mount the command box to get a feel for it and boy did she turn out it be a monster…… lol so I took it back off, going to remove thegenerator rails off and try 1 inch spacers. That will lower the command boxabout a 1 ½ inch. Then change out the tires to 31's. Hopefully it will be low enough to use the pull out side tables…
