rear plate lighting for road legal use
ari
dacula Ga
I would use these wire splices to tap into the tail light wires so the license plate light turns on when u turn on the lights. images (5).jpg
snowtrac nome
140
western alaska
I would not recommend a wire tap I would recommend the use of soldier and liquid electrical tape that way you are insulated and corrosion will never be an issue
Havok
Boston/MA
These military guys have a set up that plugs into existing wiring. With brackets as well. It's a solid set up just remember to ground t to the body.
Sent from my XT1650 using Tapatalk
papakb
1,196
San Jose, Ca
At the time I did mine LED lights weren't available so I sandwiched a dropping resistor between the license plate frame and the airlift bumper to drop the 24 volts down to 12 for the light. Today there are plenty of 10-30 volt LED light options available online that can be wired directly into the electrical system to do the job. A quick search on Google will take you to all sorts of sites that sell them.
Make sure that when you wire it in as stated above, don't use crimp style wire taps. You want a solid connection that won't nick the wire and cause a break point. The best system I've seen is the 3 way splitters (also online) that just plug into the existing wiring. Full military look without needing to be taped or covered.
riderdan
20
Central Kansas
I was out of town for a week so I missed this, but you can buy the Packard connectors and make a "Y" that will plug in to the wiring harness without cutting/splicing/soldering anything on the harness. I bought a male and female connector and created a "Y" that plugs into the harness at the horn (so the power is controlled by the blackout switch) and then ran leads to where I needed 24v power.
TOBASH
3,925
Brooklyn, NY
You guys are turning this into a government contract... I would scotch-lock the sucker, liquid tape it, and move on!!!!!
I agree. I would go 1 better. Put a solar powered light on the area. Set the light to go on at night. You can alternatively place a light with a nine-Volt battery, and allow it to stay on the entire time during the inspection. That is it. After the inspection, he might even allow the device to fall off.
Infidel got me is 100% correct.
T
kcobean
Sterling, VA
LOL...well, around these parts, if you're driving a vehicle on road and it doesn't have a plate light, you're likely to get pulled over. I think I'm going to do what someone else did and just register it as an Antique because then I'm not subject to state inspection.
