M-Series Wiring Harness Connector Help Needed
Austringer
35
Atlanta, Ga
I am in the process of building a wiring harness for a vehicle I'm restoring and I'm having some difficulties. I have new mil-spec 14AWG (as it calls for in the manual), but I'm having problems finding some of the cannon (circular) male and female plugs I'm looking for along with the male and female pins for them. I have found some of the items I need by buying NOS wiring harnesses on ebay (when cheap) that have some of the items I need. I've ordered a few dozen male and female packard connectors from Erik's.
I'm having difficulty figuring out what tools I need to push in / extract the male and female connectors in the cannon plugs. Not sure what size (the wire is 14awg) and model to use.
I'm also having difficulty finding the following connectors...
1. Plug Assembly 7976648
2. Other sized male and female cannon plug assemblies for 1,3,8 and 12 pin connectors.
Is there a good place to find these or would it be better to take the old one, have it stripped down and re-zinc plated?
jbayer
10
St. Aug., FL/ McGrady, NC
NSN's would be more helpful.
The "1. Plug Assembly 7976648" comes up as a "CAP ASSY" with a lanyard for a utility outlet.
There are numerous different styles/types of cannon plugs with 1,3,8, and 12 pin connectors.
Again NSN's would be more helpful.
If you have a MIL # that would help too.
silverstate55
Unemployable
2,128
1,086
UT
Find a local electronics store (NOT the big-box type, but a good local one with knowledgeable employees), they should stock the tools you need and hopefully pass along some expertise as well. Sometimes you get lucky and find an employee who has past military experience with rebuilding/repairing electronics and can be helpful.
ETA: I did see that you list Atlanta as your residence; that's why I posted this. I thought that with such a large metropolis as well as a large population of veterans around you, you stand a good chance of finding what I listed above.
pjwest03
37
Vestal/NY
The pin tool(s) required depend upon the series/pin sizes involved. They are generally under M81969, anywhere from $0.50 - $10.00
Most cannon plugs can be ordered from Mouser. They can be found from the MIL # and usually can be inferred by starting with the NSN.
papakb
1,196
San Jose, Ca
Jason, I have a full set of extraction and insertion tools that I can lend you to finish your job. Send me a PM if interested.
Kurt
KG6KMJ
1,160
Hey Jason,
I am currently building a couple of electronic devices with m-series connectors and it is incredibly difficult.
There are so many styles, sizes and pin arrangements, it's almost impossible to find exactly the one you need.
You'll find that your basically going to have to become an expert on these connectors.
You need to start here: http://www.amphenol-aerospace.com/pdf/faq/knowconnectors.pdf
Then go here: http://www.amphenol-aerospace.com/pdf/catalogs/12-020.pdf
If you're lucky, you'll figure out what you need and you can find the part # and search for it here: https://www.mouser.com/Connectors/C...ectors/Circular-MIL-Spec-Connector/_/N-9ulxv/
Austringer
35
Atlanta, Ga
I've been able to find some NOS connectors by buying them off ebay for older vehicle wiring harnesses. The ones I don't think that I'll be able to find, they are in decent condition, just the yellow zinc has turned grey etc. I figure those I'll just pull of, strip down the connector (remove wires and rubber parts) and have them re-yellow zinc plated locally. I'm in the process of pulling the wiring harness off now as it is complete, just most of the hull harness is baked and cracked and most wires are exposed but there is enough of it left to know where the tape starts and stops etc. The big cables such as the generator to regulator I can clean up the wires and rewrap with the rest of the wires from the engine wire harness. The starter relay and solenoid cables are in good shape, just need to clean and treat them with either 303 protectant or brake fluid. They are a little stiff but not cracking.
Here are a few pictures of the what I'm having to build.
Starter Cable Section 1 - Good condition, needs to be cleaned up and preserved, will remove the metal connector and have them re-yellow zinc plated. Same for section #2 below.
Starter Cable Section 2
Accessory Outlet Power Plug
Instrument Panel Harness
Need 4 of the "G" marked item, the little rubber shock mounts for the regulator
Hull Harness
Engine Harness
Hey Jason,
Crazyguyla
124
Altus, OK
There was a thread way back in the day that answered the question of where to find 'canon plugs". If I remember correctly, marine electrical suppliers should have or be able to order all the plugs, rubbers, and shells.
Guyfang
26,894
Burgkunstadt, Germany
I have a lot of wires and wire repair kits. Ill see if I can find any of that stuff.
If Gimp has the repair kit, most of the single rubber male/female plugs are in it, along with removal tools, crimping tool and clips. One of the army's great weaknesses is just this. Plug repair.
I can can not see what kind of vehicle it is, but the TM looked older. If the vehicle is real old, finding the big plugs becomes very difficult.
