TexasFlu419
- 5
- 3
- McKinney/TX
I need information on which wiring harness, or section of a harness, is required to connect the transmission breaker and relay to the rest of the vehicle, pictures of how it all attached would be very much appreciated, and if anyone has had luck with the Iron Clad Assurance on transmission/wiring issues.
Rest of the story: I received my M1045A2 on Wednesday night. It is my third HMMWV, but the first with the 4L80E. Regardless, I was very excited, until I realized the next morning there was only one forward gear. After a few hours of searching on the internet and checking out the HMMWV, I discovered that the wires coming from the transmission circuit breaker and relay were cut.
There are seven cut wires coming out of the breaker/relay box, and only four that are hanging as a bundle in the trans tunnel. The ones in the box still have the numbers on them, and I traced three of the trans tunnel wires back to the J2 connector on the TCM. Here is what I found:
Breaker/Relay Box : Trans Tunnel/Other Wire
290/291/537 : Assume this goes directly to some location in the Battery Box, but where?
290A/291A/537A : First wire traced back to terminal D on the J2 Connector – Connect to the A’s?
290B/291B : Attach to same terminal D wire above?
Ground in Battery Box? : Second and Third wires traced back to terminals A and F – Wire both straight to ground?
290C/291C : Maybe the fourth wire is 291D/657A - connect?
537C : Do not see on the diagnostic chart – where to connect?
29T : Connect somewhere in Battery box (29D?)?
57T : Connect somewhere in Battery box (is block on side of the battery box wall the shunt?)?
Even after I get this all wired up, the trans could have a mechanical problem that initiated the cutting. The Iron Clad Assurance does not cover anything requiring going through the trans gears to discover, but since it starts in second, maybe I have a shot. Anyone have any luck disputing trans issues with Gov Planet?
Sorry for the long-winded and convoluted post. Any help is appreciated.
