I am asking if someone has taken one apart to repair it. Diagnosing whether it is bad is easy.diagnosed? to determine it is bad? or taken it apart to repair it.
I could imagine that the sender units pipe is too long to just pull up and out.why not the right part? looks right to me. I am going to try to repair mine but the fuel tank is full and apparently the tank most be moved to get it out.
Tom
I bought a spare OEM one from Suprman. Maybe he still has one.I know the sender is faulty. it shows open when it should have a resistance. I just wanted to know if someone had opened one up, yet.
Alternatively: Does someone have a replacement>
Mine shows empty right around the same time the engine stops running...Short the 2 wires out on the sender and see if the gauge pegs out full. Gauge should show a little low though no matter what. Mine shows empty and i have about 14 gallons left.
https://www.steelsoldiers.com/showthread.php?165281-Fuel-gauge-sending-unit&highlight=fuel+gauge
Thats not good. Priming the fuel aystem isnt funMine shows empty right around the same time the engine stops running...
WOW, that is impressiveRan it dry 100ft from the gas station, walked it, filled a jerry can, walked it back, put the diesel in, started right up. No problems.
