Hello forum.
I know that there are a lot of CTIS threads, but I didn't found any usefull info, probably because I am blind... Sorry about it
I have a M1078 with CTIS partially working. I will try to explain what happen:
- Air tank is full at 120psi
- CTIS starting to work (hwy blinking)
- I hear that the tires are inflated (no air leak, but small flapping noise from the quick release valve?)
- sometimes it is interrupted (due pressure check)
- goes on for about 5 minutes
- ctis stops inflating and vents the tubes (the "hiss" in front)
- ctis hwy light is steady
- front quick release valve is venting about 10-15 seconds, then stops (like a italian mocca coffee machine
- CTIS is doing the 30 second test (blinking again)
- CTIS starts all cycle again
What I checked:
- wheel valves are OK, they do not loose air. I loose the banjo bolts and hear no sound
- all tire pressure are 90 psi. Probably because of a change of the ECU.
- pressing another terrain button deflates. I didn't wait to see deflating the tires but both quick release valves are venting...
- I had a massive air loss in front wheel valve, change the diaphragm and now keeps the air.
It is normal that after inflating cycle and venting the quick release valve open for 10 seconds?
Can be that the from QRV have an issue?
Can be dangerous having 90 psi on a m1078?
Thanks and regards from Italy
Christian
What I checked:
Christian
