Question: Could I convert a 6bt marine cummins to a normal 6bt for a deuce?
Mandalore
Lubbock, Texas
Been watching Garret do his 6bt engine swap on his truck and It got me to thinking I might want to do the same thing when my multifuel eventually dies. With that being said, I see some 6bt marine engines on auctions sites and I was wondering how difficult it would be to try to convert it back to a normal 6bt. What would be involved and would it be worth it? I know some of you will say something along the lines of " Why would you want to do that? Just put a new multifuel in" etc. Its just what I have been thinking about.
Recovry4x4
LLM/Member 785
1,824
GA Mountains
Well, I can't say anything specifically but if you do buy one, make sure it's not reverse rotation. I've seen marine engine pairs where one rotates backwards.
willys47
saskatoon sk
I put an industrial 5.9 in my pickup to get it to work in an automotive application my pump guy had to get some parts shipped from bosh to make it work properly i also changed the governer spring and fuel pin and remember about the killer pin
162tcat
Washington
If someone buys a marine 5.9 I'll gladly trade it for a low mile 12 valve that's still in the truck. You can hear it run. Would come complete from top to bottom.
Jeepsinker
470
Dry Creek, Louisiana
Not much difference. Just bolt on ancillary components that are simple to swap. They also have a high nickel block ( stronger alloy), and an extra turbo drain boss which is nice if you decide to run compound turbos. The pistons and injectors are different so you will need to keep that in mind if you plan to do future upgrades. A marine engine should be 300 horse stock. No reason you would need more than that, but you might want more someday. Bigger injectors mean more heat, so be sure to have a good radiator.
WillWagner
3,158
Monrovia, Ca.
Heads are different too, swirl factor is different. You'd need the pump gone thru and set it to an automotive style governor. Oil pans are a flat aluminum type, that would need changing to clear the front axle along with the oil pick up. So basically you would need a head, pistons, exhaust manifold, turbo with all the plumbing, oil pan, probably an alternator mount and stat outlet, air compressor and plumbing if the marine engine didn't have one and a fan hub because the marine engines usually had a fan hub that was a very low mount that would not work for a fan center/radiator in a truck. There are other things to think about too, like what speed do you want to turn the fan at, 1:1, 1.2:1, .87:1? Dipstick, you changed the pan so now you need the right dipstick for the pan sump and capacity.
Just a few bolt on parts.
Jeepsinker
470
I wasn't aware the heads were different. I thought I was just piston and injectors that changed the swirl. I say this because some guys install marine pistons and injectors in on road engines for performance and the spray lands in the right place in the bowl. The pump governor is easy enough to change the flyweight assembly yourself if you aren't scared of it.
WillWagner
3,158
Monrovia, Ca.
Swirl factor is cast into the head. On 2 valve heads it is marked on the head, cast into it, located on the intake side, front top, where an A/C mount would bolt, S1, S2 and S3. I forget about 4 valve heads.
