The kit was around $3500 I believe (give or take) from Mike over at Dirty Boyz Off Road.Joe how much did the 700r4 conversion cost you?
I stopped by the shop working on my Humvee today and asked how the "magical" TV bracket worked out and I quote:Well I found the elusive TV cable bracket today. Got it thru Dirty Boyz in a roundabout way.
As of 3/5/19 the trans is fully installed in the truck and all seems to be well. The shop that is installing it for me is finishing up aAny updates Joe on how the conversion went and how it drives?
Ask and you shall receive …Pictures or you didn't do it !!!! lol
Yeah, I don't play that game !It's not leaking, it's marking it's territory!!!
Great to hear.Just past 500 miles on my swap....no issues to report.
I have a tachometer kit but haven’t installed it yet, so I have no RPM information to share. I can now cruise 50-55 comfortably....37mph is about the shift point for the OD. It is a definite benefit, but if you’re expecting after the install you’ll be running down the interstate with traffic you would be a little disappointed.. in summation it makes running 55 feel ok and not like the engine in about to come apart. It does not make you feel like running 70 is no worrris....just how I see it.Great to hear.
What's your "average" cruising speed and RPM with the 700R4 in your truck ?
I guess every truck is different.I have a tachometer kit but haven’t installed it yet, so I have no RPM information to share. I can now cruise 50-55 comfortably....37mph is about the shift point for the OD. It is a definite benefit, but if you’re expecting after the install you’ll be running down the interstate with traffic you would be a little disappointed.. in summation it makes running 55 feel ok and not like the engine in about to come apart. It does not make you feel like running 70 is no worrris....just how I see it.
I think we all have pumpkins with 3 versions of gearing. I will be swapping in 2.58 gears (or is it 2.56?). I will then swap in the 700R4 using the Bowtie tranny system.I guess every truck is different.
Before the swap with my 6.5L/3 speed I could cruise the truck at 60-65mph without the RPM's screaming too bad, and maxed out I hit 75 via a GPS Speedo app on my phone.
Along with the trans I also got rid of the stock / heavy wheels and tires and went aftermarket so from what I have read should help on the MPH department as far as loss of rolling weight and such.
We shall see this week...
I am curious what RMP I am actually turning...who knows I may just be sensitive to all the noise. Could be turning way less than Max RPM, I just don't like tearing stuff up. good luck with you install man, I am looking forward to reading all about it.I guess every truck is different.
