M1010 relay panel wiring
Oerthedge21
20
Northford CT
Finally tracked down a new relay panel for the 1010, only to find I have no clue where any wires go. There's the connectors for the relays, which ones go where I don't know, and then there's a few cut wires from the fuse block, as well as wires with ring end terminals on from both the truck side and panel side wiring. Some help here would he great since I'm not looking to fry my electrical setup IMG_20190316_131139455.jpgIMG_20190316_131131004.jpg
319
Lieutenant
3,347
58
Michigan
Finally tracked down a new relay panel for the 1010, only to find I have no clue where any wires go. There's the connectors for the relays, which ones go where I don't know, and then there's a few cut wires from the fuse block, as well as wires with ring end terminals on from both the truck side and panel side wiring. Some help here would he great since I'm not looking to fry my electrical setup View attachment 758293View attachment 758294
These may help
Oerthedge21
20
Northford CT
Yes that definitely cleared it up some, although I am left with two wires now, an orange, and a second purple both coming from the fuse block. I can't seem to find them in your pictures. The orange runs though a 15 amp fuse, as does the purple. I connected the other purple to the yellow relay, which appears to say heater, and it runs through the 30 amp fuse. Is that correct, or should the yellow relay be connected to the purple that goes through the 15a fuse? And as I said, do you happen to know where the second purple and the orange go to?Snapchat-1308392637.jpg
Mad Texan
1,151
Chester County, PA
Yes that definitely cleared it up some, although I am left with two wires now, an orange, and a second purple both coming from the fuse block. I can't seem to find them in your pictures. The orange runs though a 15 amp fuse, as does the purple. I connected the other purple to the yellow relay, which appears to say heater, and it runs through the 30 amp fuse. Is that correct, or should the yellow relay be connected to the purple that goes through the 15a fuse? And as I said, do you happen to know where the second purple and the orange go to?View attachment 758306
Looking at the F-25 wiring diagram of TM9-2320-289-20 Pg 879. All the 15 amp circuits are for the service outlets found at the ends of the bench...
