BuiltMFG
- 5
- 18
- Denver, CO
I have an 1078A1 with a winch. On the top of the Heat/AC resides a switch panel with a few switches for the winch, but a lot of harnesses for switches that are not there.
If I am reading the wiring diagram correctly, are the switch harnesses wired with everything except the outgoing positive wire to an accessory? In the diagram some them are labeled as unused but some have more wires than others. One is even labeled as "PTO" in addition to another working PTO harness (which works)
The tags on the harnesses are P904, P905, P906, P908, P909, P910, P911, P915
I'm asking because at some point I want to add switches in this location... preferably using already existing switch harnesses.
![IMG_0394.jpg IMG_0394.jpg](https://www.steelsoldiers.com/data/attachments/521/521562-c3675973293c8385406e39e6a8288ef3.jpg)
