Jakelc15
- 36
- 28
- Hanover Pa
My helper spring is right at 2" to the pertch. The swing shackle is about 5° out from verticle. The spring pack being slightly longer than its frame mounts.
Gotta love studs and sleaze!The stud is my my cut off unbolt and 3/4x1.0 sleaze.
Yep....well no.Gotta love studs and sleaze!
Yes it is ! I had my old 1954 deuce's trunnion assembly hot galvanized back in the early 90's. I was still strong then and still it was a pain to remove !That trunnion is solid steel, I think!
Yes, putting 2 or 3 conduits in the boxed frame sounds like a smart move to make future add-ons much easier.
I had the M105 springs already. For some reason they seemed too heavy when on the trailer frame but as I prepared them and had input from others, they are not as strong as I first thought. I like the idea of needing no air in bags when I don't have a payload.Glad I could help.
Why not do a full air ride?
That is a very creative solution ! Well done !Well, don't go with a 3" space if you plate the side like like I did, go 2" or 5" lower than the frame but don't go 3" or 4", the attachment bolts end up too close to the flange. I went 3" and have to make the bolt reach clear through to the edge of the flange. I'll make a detail of my solution and edit this post with a picture.
Edit... I added photo of my solution for ending up in the bend for the spring mount.
It's always considered best to use two drive-shafts when they get near the max length. When I worked at IHC, one of my jobs was installing the differentials on the "Sliders" (cab and frame and engine only) . Some wanted tandem axles. Some wanted shorter frames and single axles. Some wanted long frames and single axles. Whatever the customer wanted. So I would have to cut the frame to the customers length and install a single or tandem axle, plus whatever suspension system they chose. (I used a Milwaukee "Mag" drill a lot ! Still have my old 5/8" shank one on the shelf. Weighs a ton though).Time to work out the drive-shaft for the truck rear axle. I measure and the length needed is around 84" (that's 7' 0") for a one piece driveshaft. An older post has a link to Spicer but I can't copy it. On page 18 there is a chart that gives the max critical length for each size shaft at the max rpm.
The deuce is 3" and the Cat can go around 2500 rpm with a 1.1 final drive. The chart says 76" is the max length. If I drop to 2000 rpm, the same shaft can be 85" long.
That seems to put me on the edge of having a one piece driveshaft versus one with a carrier bearing. I really would like to avoid the carrier bearing. That said, here is what I think will work for a carrier
I'll have to confirm but it appears I can turn the first shaft around and run the carrier bearing on the solid shaft where the splines and slip yoke are. I can make it line up with the TC output with 0 angle. I don't need the slip joint on that side of the bearing then, just the u-joint.
I think I can use the 2 driveshafts removed to make the one new one needed.
