turn signal cancel ring
m998tom
Tenino Wa
anyone have a lead on a turn signal cancel ring. I just cant seem to spend $27 plus shipping on something so simple but maybe I am cheap. Im probably cheap.
AOR
37
Burtonsville, MD.
I purchased the real deal I only like to do things the right way but someone told me you can use 2 screws to do the same function
TOBASH
3,924
Brooklyn, NY
So, I usually prefer OE/OEM. I called RWH, and he said I need to change out my steering column in addition to steering wheel to use OE ring. Lots a work. Lots a $.
SO. decided to make a wooden ring of correct size, cut in half and hold to the steering wheel with screws and epoxy, and drill a few holes to place plastic nails through to cancel the signal. I won't use screws as they will wear through the plastic in the canceling thingy.
When I make it, I will shoot a few pics.
5,145
I saw somewhere that someone had made one out of PVC pipe. I thought about getting one, but with having it setup as a slantback with X doors, that dang indicator light is blinding to me I never forget about it on the HMMWV.
Wire Fox
162
Indianapolis, Indiana
Ain't that the truth. The worst fate to suffer: needing to have your 4-way flashers on at night, rolling miles and miles down the highway. I just rest my left hand over the ****ed flasher indicator and drive one-handed until I need to actually turn. Otherwise, it's an hour of being blind 50% of the drive.
TOBASH
3,924
Brooklyn, NY
Duct tape, painters tape, light bulb removal, an old sock, and even tinfoil can block out that light. Just sayin’
Wire Fox
162
It's perfect in the daylight, which is 95% of my driving, so no sense in permanent modification/disabling. I still want to see the blink at night, just not as bright... Maybe I'll make a second little cap for night use, or just slap a piece of tape on the top of it just to not be beamed in the face.
Sent from my Nokia 6.1 using Tapatalk
TOBASH
3,924
Brooklyn, NY
Might I suggest a few thin coats of dark green automotive spray paint? Just like with hidden rear lights on modified classic cars, it will darken the light but not totally kill it. Or a few pieces of 30% window tinting
Milcommoguy
2,396
Rosamond, CA
Nothing a little black tape wouldn't fix. Wrap the bulb or LED so only the tip is clear or slip a plastic sippy straw over it or peice of shrink sleeve or paint it out a bit or ....
Cat skinning is easy. Light dimming easier, CAMO
