- 475
- 275
- 63
- NorCal
M35A3 Allison 643 - has anyone done it?
Hello,
I've arrived at a crossroads with my M35A3: after spending time the past few weeks, and with several quality folks throwing their shoulder behind the effort, it's turned out that the front pump I need for the Allison 1545 in my truck is apparently made of unobtanium.
A huge thank you to those you have pitched in thus far. Some valuable things have been learned (which I shared - search for 1545 retrans)
So now, I'm faced with using either a 545 or a 643. They both have their plusses an minuses:
545: pro: bolt up. Cons: no lockup and uncertain on gearing of 4th.
643: granny 1st, 5 speed, with (some?) lockups, and a beefier transmission. Cons: physically larger and potential bellhousing/tc housing issues ala length/overall fitment.
So.
Has anybody actually done the swapout of a 1545 to a 643? Not thought about it - but actually DONE it? If you have approached this and wound up not doing it, why not?
Regards,
SJ/JD
Hello,
So.
Regards,
SJ/JD
