- 86
- -1
- 6
- Kenosha WI
Im sorry, could you explain this a little. not sure how id have it off and test its pressure at the same time. thanks.you need to remove the metal line from the top of the air compressor. You need to have it off when the pressure reaches 120psi and see if you have air coming out of it at that psi.
