- 7,391
- 2,438
- Interlachen Fl.
Would seem like when the G code came out it is a IP just about like any other. Heck might have been even better with the oiling system. There were probably heads still floating around out there and the blocking kits too if the correct head could not be found. One would think that the blocking kit could be made. You have the IP does it look like you could make one up? It has to be correct and never leak / fail. If so then you could be helping others that might just have G and have to replace the head that does not have the oil port.
