Deuce will not start after several years of sitting
camsoup
Tennessee
Hey everyone,
I’m new to this group! I’m with Sumner County Emergency Management in Gallatin, Tennessee. We’re in need of help with our deuce. Our truck hasn’t been started in roughly 6 years. Went to try and start it with brand new batteries as of today. When you flip the power switch, you can hear the fuel pump hum but that’s it. No crank or anything when you push the ignition button. I ordered a new button. What do I need to be checking for next? All help is appreciated. Also if your local or nearby and know these trucks well, I’d love to pick your brain!
USAFSS-ColdWarrior
Chaplain
6,251
Welcome aboard :D
Find a bunk, stow your gear, and prepare to get underway :driver:
As for your questions about the Deuce you have....
I'm sure others will be chiming in soon. Have you looked up the TM's (Technical Manuals) for it yet.... M35A2 or M35A3 I suppose?
Included in those publications are troubleshooting procedures as well as many functional explanations you really ought to be familiar with when "reviving" a dormant vehicle from its sleep.
Again, WELCOME!
camsoup
Tennessee
Welcome aboard :D
Again, WELCOME!
Thank you, I’m excited to be here to learn from y’all! I have not looked at them yet, is there a place I can find them?
porkysplace
1,496
mid- michigan
Since the TM's your looking for are buried in the deuce tm section , here is the link to the TM's
Listed below are a number of the TM's for the M35 trucks. To save them to your computer, right click, select "save as".
GTA-9-1-1851-8.pdf M35 complete diagram of with descriptions of all components.
LO9-2320-209-12-1.pdf
LO9-2320-209-12-1 Lubrication Order for the M35 series.
TM9-2320-209-10-1.pdf
TM9-2320-209-10-1 Operation, Installation and Reference data for the M35 series, Operator Level.
TM9-2320-209-10-2.pdf
TM9-2320-209-10-2 Scheduled Maintenance Operator level M35 Multifuel.
TM9-2320-209-10-3.pdf
TM9-2320-209-10-3 Troubleshooting Operator level M35 Multifuel.
TM9-2320-209-10-4.pdf
TM9-2320-209-10-4 Maintenance Operator Level M35 Multifuel.
TM9-2320-209-20-1.pdf
TM9-2320-209-20-1 Scheduled maintenance organizational level M44 series 2-1/2 ton trucks.
TM9-2320-209-20-2-1.pdf
TM9-2320-209-20-2-1 Organization level - Troubleshooting Multifuel M35 Part 1 of 2.
TM9-2320-209-20-2-2.pdf
TM9-2320-209-20-2-2 Organization level - Troubleshooting Multifuel M35 Part 2 of 2.
TM9-2320-209-20-3-1.pdf
TM9-2320-209-20-3-1 Organization level - Maintenance M35 Multifuel Part 1 of 4.
TM9-2320-209-20-3-2.pdf
TM9-2320-209-20-3-2 Organization level - Maintenance M35 Multifuel Part 2 of 4.
TM9-2320-209-20-3-3.pdf
TM9-2320-209-20-3-3 Organization level - Maintenance M35 Multifuel Part 3 of 4.
TM9-2320-209-20-3-4.pdf
TM9-2320-209-20-3-4 Organization level - Maintenance M35 Multifuel Part 4 of 4.
TM9-2320-209-20P.pdf
TM9-2320-209-20P Organization level - Maintenance M35 Multifuel repair parts and special tools.
TM9-2320-209-34-1.pdf
TM9-2320-209-34-1 Troubleshooting Direct and General Support Levels.
TM9-2320-209-34-2-1.pdf
TM9-2320-209-34-2-1 Maintenance Direct Support and General Support M35 Multifuel 1 of 3.
TM9-2320-209-34-2-2.pdf
TM9-2320-209-34-2-2 Maintenance Direct Support and General Support M35 Multifuel 2 of 3.
TM9-2320-209-34-2-3.pdf
TM9-2320-209-34-2-3 Maintenance Direct Support and General Support M35 Multifuel 3 of 3.
TM9-2320-209-34P.pdf
TM9-2320-209-34P Direct and General Maintenance and Support Parts and Special tools.
TM9-2320-361-20.pdf
TM9-2320-361-20 Technical Manual and Unit Maintenance. (Later Edition TM)
TM9-2320-361-20P.pdf
TM9-2320-361-20P Unit Level Maintenance M35 Multifuel Repair parts and special tools. (Later Edition TM)
TM9-2320-361-24-1.pdf
TM9-2320-361-24-1 Field and Sustainment Maintenance 1 of 2. (Later Edition TM)
TM9-2320-361-24-2.pdf
TM9-2320-361-24-2 Field and Sustainment Maintenance 2 of 2. (Later Edition TM)
TM9-2320-361-24P.pdf
TM9-2320-361-24P Repair parts and special tools lists Field Sustainment Maintenance. (Later Edition TM)
TM9-2320-361-34.pdf
TM9-2320-361-34 Direct Support and General Support Maintenance M35 Multifuel. (Later Edition TM)
TM9-2320-361-34P.pdf
TM9-2320-361-34P Direct & General Support Maintenance Repair Parts & Special Tools List. (Later Edition TM)
LO9-2320-386-12.pdf
LO9-2320-386-12 Lubrication order for the M35A3.
TM9-2320-386-10.pdf
TM9-2320-386-10 Operator manual for the M35A3.
TM9-2320-386-24-1-1.pdf
TM9-2320-386-24-1-1 Unit, Direct and General Support Maintenance TM for the M35A3 1 of 2.
TM9-2320-386-24-1-2.pdf
TM9-2320-386-24-1-2 Unit, Direct and General Support Maintenance TM for the M35A3 2 of 2.
TM9-2320-386-24P.pdf
TM9-2320-386-24P Unit, Direct and General Support Parts and Special Tools lists for M35A3.
cattlerepairman
3,513
NORTH (Canada)
- batteries hooked up correctly for 24V and at good voltage?
- battery cables well attached and the cables itself are not chafed where they go through openings/over edges?
- transmission is in neutral (you sure?) and you depress the clutch before attempting to start?
- grab a fan blade, press down on the V-belt and try turning the engine a bit, back and forth. Does it move? Feel smooth when it moves?
- starter sits on the passenger side, the solenoid is above it, attached to the engine block. Does it click when the start button is depressed?
WillWagner
3,156
Monrovia, Ca.
Get out a DVOM and check voltage at the starter solenoid when the button is pushed, check grounds, visually inspect it for damage from critters, they seem to like the taste of wire insulation!. Don't go throwing parts at things, trouble shoot it.
Floridianson
2,528
Interlachen Fl.
Since the truck has not been started for that long remove the shut down cover on the IP. Check the fuel control unit assembly for free movement. Fuel control unit assembly should look like it is about the 7 o'clock position with you finger you should be able to push it to the rear about the 4 o" clock position and it should snap back to the 7 o'clock position. Always leave the shut down cable pulled out after you shut down the truck.
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
Yeah, as James said, a few things need to be done.
First thing I'd do is turn on the power switch and open the fuel bleeder on the secondary filters to verify fuel flow.
Next I'd check the fuel shutoff for movement. If it doesn't move, I wouldn't try to start it.
If it does move, I'd start checking voltage at the starter botton and then the relay that should be on the side of the motor block, just above the starter.
Post back up and let us know what you find!
Floridianson
2,528
Interlachen Fl.
Yep good call Chris never hurts to make sure fuel is circulating if she has not been run in that long of a time. It does not hurt to let the in tank pump run by it's self. Also if you find the fuel control unit assembly moving free do not forget to push the cable stop back in before you replace the cover if you did not do it before you removed the cover. This is an easy check of the fuel control ( two screws) and can prevent the motor from going wide open on start up. There has been fuel control unit assembly so stuck the shut down cable could not over come it or shut the motor down. You can only guess the mess in your paints after a runaway.
fasttruck
638
Mesa, AZ
Another potential electrical gremlin is where the ground wire from the battery is attached to the frame. Take this off and clean it as it probably hasn't been touched since the truck was new and corrosion forms here. Remember: if you can't fix it with a hammer you have an electrical problem.
Floridianson
2,528
Interlachen Fl.
The OP did not even get to the point of the engine cranking over. Maybe that should be the first achievement?
Yes and no to many people have not checked or even know about the fuel control till it's to late. Getting it to crank over is a small problem going to wide open throttle can be a big problem. That is the first thing I check on a truck I do not know period.
tenmilebay
Nashville, Georgia
This is so true. Thank you Floridanson for the reminder. I haven't cranked my ole girl in awhile and will check out the shut off before I try to fire her up.
will need new batteries for sure. thinking about going to a different group battery & reconfigure my ole box
Looks like I'm in the same boat with you (camsoup) & welcome
gimpyrobb
27,787
778
Cincy Ohio
Yeah, as stated, it can save a lot of problems to verify a few other things first. By the time the truck cranks over, it would be too late to realize the fuel shut off doesn't work. Some simple preplanning goes a long way here.
cattlerepairman
3,513
NORTH (Canada)
10-4 on that. Good point. I definitely thought more of a fuel shut off stuck closed as the next issue.
Sent from my SM-G950W using Tapatalk
Floridianson
2,528
Interlachen Fl.
Almost needs to be a sticky with big red letters. Always know about you fuel control and always leave the shut down cable pulled out after use. Problem someone who has not been to Steel Soldiers and does not read the sticky. They want a Deuce they find a Deuce they go to start and it goes to wide open throttle. They then get to hear about Steel Soldiers and there first post is I bought a Deuce and it went to wide open throttle what happend?
