gentrysgarage
- 118
- 43
- Lost Angels, CA
HiYa Guyz,
Got a question for you. I am placing everything in the chassis for the 6BTA Cummins conversion in my M135 and can't quite fit the Ross HF 54 in front of the axle, due to rad/intercooler and the eventual air compressor (that is if I can A get the motor bracket for the Bendix 550 compressor I already have that was out of a BlueBird bus..or B get a single cylinder compressor of a medium duty Ford...that I have the motor bracket for! SMH) so I will be mounting it behind the axle center-line. The M135/211 has a dip in the frame for axle travel also that has to be compensated for.
Enough of the backstory the question I have for the group is how short can I make the drag link be.
And if GoodwithWood is reading this I have had a nagging question as to where you got your "rebuilt" HF-54 that wasn't quite rebuilt right...I am worried mine came from the same place.
Thanks in Advance!
PS No I am not making it for the Ozzie Outback, I just don't have room on the left side of the truck to take a side view to show the frame rail! LOL!
Thanks in Advance!
