charlesmann
- 713
- 93
- Temple, Tx
2 fold query.
first off. How the heck do you get the dang tire/wheel off the axle? i got the front tires off no problem, but getting the rears over the axle/hub flange seems to be a booger. any easy ways? couple pipes over the studs then slide it off on the pipes? if there is no easy way, there will be 2 A2 wreckers up for sale very soon.
iv got a leak down in my sec air system. can't seem to find it. i know when i disengage the t-case pto, i do hear air bleeding off in the intake.
i did the air brake leak test/check according to the DOT requirements, and it will pass inspection, but id like to know if the sec tank bleeds off into the eng intake.
