So I have navigated old threads to the best of my ability. I recently picked up an 803a with 500 hours. Last night I changed all filters and fluids, also replaced the temp gage that was broken. I fire it up and within a few short minutes (maybe 4/5 min) the temp was at 200 + degrees. It wasn’t idling high and there was no load on it. All the fluids were filled correctly and double checked. So I backed the throttle down and got it to stop rising at around 210. Gave it some time and it slowly started creeping back up so I shut it down. I reached in and put my hand on the radiator because it felt cool blowing out of the top, and it was cold. The top hose was pretty hot just felt saturated from the motor heat, but the bottom hose was very cool pretty much the ambient temp of outside. I’m thinking the thermostat is stuck, the unit was drained and I’m guessing it was for some time. So my questions would be if you agree with the diagnosis? If the thermostat I got works on the same ohms as the old one, it looks different but is made by the same company I got it off of eBay. Also I have read in other posts that a standard Chevy thermostat works “perfect”. I am a ford guy lol so what is standard? A small block Chevy thermostat? I will attempt to attach pics of the thermostats.![A5958997-D2F3-4E52-BFD7-99218BDAD21F.jpeg A5958997-D2F3-4E52-BFD7-99218BDAD21F.jpeg](https://www.steelsoldiers.com/data/attachments/549/549688-dfa2a34f4def58a3c53c19310545888d.jpg)
![6263BC27-28FE-46B1-A118-AD90C5C21A91.jpeg 6263BC27-28FE-46B1-A118-AD90C5C21A91.jpeg](https://www.steelsoldiers.com/data/attachments/549/549689-74c58d377209c3745481008dae42f2bc.jpg)
