- 201
- 89
- 28
- Oahu, Hawaii
EGT and Boost. Did my first run with a new to me D turbo, EGT and Boost gauge. The highest EGT was 1100ish before I backing off the throttle, highest RPM was 2450 ish, Max MPH 52, tire size 11.00-20 ,max boost seen was about 14 lbs, max load was approximately 1700lbs of cement/rubbish. Even on slight hills in 4th and 5th EGTs were near 1100, while at idle they are about 400. I do have a larger exhaust and am using the Jatonka filters, I believe the fuel was turned up by the prior owner. Also approximate altitude is between 5000-6000 ft above sea level.
I'm very new to diesel EGTs so what are y'alls thoughts on performance or if there is something wrong.
Sent from my LG-H918 using Tapatalk
