Anyone familiar with power distribution box on M1083
chucky
19,298
TN .
Question for the electrical gurus on here know if we can do away with this box and bolt the cables directly to each other { from same post of coarse} I was cleaning the 4 post on mine today and got to the bottom of the 4th stud takeing the nut off with a 4 in long 1/4 in ratchet and not even hard to turn and BAM i snap off the stud off flush at the box ! Does anyone know which stud does what on the box from top to bottom? What to do can i just bolt those 2 cables togeather and leave the others conected to the dist box or just remove the box??????
NDT
7,478
Camp Wood/LC, TX
The consensus here is it’s ok to get rid of or bypass the polarity protection device. Just don’t make a mistake if you jump it off because lots of expensive stuff will go poof.
There are 4 terminals, 2 are 12 volt in and out, the other 2 are 24 volt in and out. Most people do just like you say, double lug the appropriate cables together on one stud.
chucky
19,298
TN .
Thanks i was just reading one of your replys on this same subject , Since it was the bottom lug i will just move those 2 cables up to the next lug which i beleave thats all 12 volt i was going to put a meter on it in the morning to double check !! Ronmar i think it was not sure i read a bunch had said i could get a 150 amp fuse and put it between the good and bad post .
Manncayden
Texas
Having the same issue did you end up putting a fuse between the good and the bad or just bolting together without?
Ronmar
8,355
Port angeles wa
You don't really need the fuse. There is a digram on the side of the polarity box To confirm, and using a meter to confirm is also a good idea, but the top and bottom studs should be 24 and 12 battery and the two middle studs are 24 and 12 load. You simply put all 3 cables for one voltage(Alt, Batt and Load onto a single stud to bypass a bad diode or deal with a broken stud…
GeneralDisorder
6,186
Portland, OR
The box does nothing in relation to amperage. It's for polarity protection on the A0. If you have an A1/A1R that's a different story. The PPD (Polarity Protection Device) and the later LBCD (Load, Battery Control Device) both provide polarity protection but the LBCD does MUCH more and there are other components to the system.
