The "cadillac deuce", cab replant idea
Vintagefarmer
76
Cambridge Minnesota USA
So, first time I've been on this forum in ages. Been even longer since I posted anything. But recently I've been looking into the ol' m211/135 trucks as a chassis option for a cab swap. I've got a federal 25m truck that I've had trouble finding running gear parts for ever since I acquired it back in 2014. It's done alright, admirably even, but it's not exactly what I'd want. I've seen a few for sale lately around me and got to thinking... how hard would it really be? Any questions, comments or ideas?20190622_192427.jpg
DUUANE
248
Qualicum Beach BC
Park it on level ground. Get a tape measure. Measure the outside to outside on the frame rails.
Get a plumb bob.
On the floor mark a line where the center of the front wheel is. Then drop a second point in a different color thats the center of the front wheel well in the front fender.
Remeber which color is which.
Then take plumb bob to the center of front cab mount bolt. Make mark on floor.
Make 6 marks on each side of the outside of the frame rail with plumb bob. Mark the frame line with a straight edge on floor.
Post the numbers and ill go measure the M135 i have apart in the yard so you can see how close you are. If you have a standard 34" wide frame the issue will be the cab mount to axle centerline. If it isnt the same youll get into a steering box conversion..not cheap or particularly easy but can be done. The rest is relatively easy.
Vintagefarmer
76
Get a plumb bob.
I'm guessing I'm going to need to do a steering box conversion. If it comes down to that I'd probably cut the tube and shaft down, shove a bearing in the tube around run a u-jointed shaft to maybe the stock column. The only measurement I have at this point is the frame width which comes in at 34.5 inches outside to outside. I measured that when I was looking st throwing a flatbed on it. I'll see about getting the numbers for you when I get the truck outta the yard, it's currently mud-locked.
Appreciate it.
