erasedhammer
- 56
- 28
- Maryland
They definitely aren't the correct size, I hope they are in the right place.The bolt holes are at an angle. I can see the 3 dimples in the picture in your first post so they must be under that coating.
The hole I think you are seeing in my pic is one that looks to have been used to mount the electrical connector block to the firewall. It lines up with it.The bolt holes are at an angle. I can see the 3 dimples in the picture in your first post so they must be under that coating.
Ah I see them now!The master cylinder has to be in the right spot for the rod to line up and the required supports to go in the bolt holes. I’m not talking about the hole through the firewall, all three dimples are above that in your photo. The middle one is barely visable.
Can't find any master cyls at local parts stores, so might have to order one.It’s too hard to measure on a truck. If you don’t have a master cylinder to measure I can dig one out and look.
Can't find much online for the size, maybe 3/4 or 1 1/4"?It’s too hard to measure on a truck. If you don’t have a master cylinder to measure I can dig one out and look.
I hope I didn't just destroy my firewall.It’s too hard to measure on a truck. If you don’t have a master cylinder to measure I can dig one out and look.
Everythings back together now. Easily the most annoying part of this swap so far.Bump
How'd it turn out?
