Not sure if I understand you correctly but the key switch has to be turned in the On position before I start with the normal push button.Hii, you're absolutely right. I'm at that point now. Can you explain to me in a little detail how you connected it? So I understand for the key to work you have to have the button pressed to turn on with a key? Or is it the other way around?
Unfortunately mine is not the sameHere's pictures of my regulator with the green lights I spoke of in your other post.
View attachment 809064View attachment 809066View attachment 809067
And my tach in use.View attachment 809071
See this threadUnfortunately mine is not the same
But maybe can works also, i will check
