New style fan clutch
Ronmar
8,316
Port angeles wa
Yes, new style has studs old style does not. You also need the new style fan to go with this... The old style fan will not match the stud placement...
coachgeo
3,546
North of Cincy OH
would one with a connection to a machinist be able to cut center out of old fan..... weld in new center and drill new holes to match? Just wondering if 150 bucks was worth this used one off a c7 to have on hand.
Ronmar
8,316
Port angeles wa
Well anything is possible with the right tools and talent. Since the plastic fan is molded around the center plate you would have to watch the heat applied...
Awesomeness
1,522
Orlando, FL
Your old fan has a center? The new fan is the one with the steel center plate. The old one is the one with the big hole through it, and the rubber grommets that many people don't like.
Andyrv6av8r
458
Spartanburg,SC
I had a friend of mine machine a plate that bolted to the old fan and had new holes for the clutch. No welding needed.
