Russ Knight
- 1,058
- Perry, FL
I'm losing air when sitting with the service brakes applied. Leaking brake diaphragm somewhere?
Leaking thru intake? Which tank pressure is losing air?I'm losing air when sitting with the service brakes applied. Leaking brake diaphragm somewhere?
It's leaking into the intake, Wes.Leaking thru intake? Which tank pressure is losing air?
@simp5782It's leaking into the intake, Wes.
I lose 20# of air pressure, out through the engine intake, every time I press the brake pedal. Did replacing the brake pedal valve assembly at the brake pedal fix the problem? Where did you buy it and how much? Thank you!Thanks to Wes, problem isolated. It is the brake pedal valve assembly. Ordered a new one today.
