Skinny
- 486
- 83
- Portsmouth, NH
I don't think you can go wrong with an LS for pretty much every reason. You can play the game of what happens if...
Well if your injection pump solenoid fails or an LS needs a throttle position sensor. Let me know which one you can have in your hand first.
I think the other part of the equation is transmission choice. The TH400 although bulletproof is a turd. The 4L80 is a far superior choice. But now that the average cruise speed on the highway is like 80 mph I would seriously consider a 6L80.
Not that I would want to swap it into a driveline that didn't come stock with it, it's a great choice. Sure if you need a standalone computer and harness it could be cost prohibited. But if you buy a 5.3 that comes with one that is a great option.
Way better step on gear ratios then a 4L80, way lower first gear, and two way taller overdrives. If you aren't going for a zombie apocalypse build, I'd consider this as a necessity if doing a non big block LS.
Sent from my Moto G (5) Plus using Tapatalk
