- 239
- 112
- 43
- Austin, TX
A few months ago, I purchased a really clean military dump bed that looks like it was taken off a M51 Dump (M35 series 5-tons) as it has the PTO driven hydraulic pump that's integrated into the dump frame. My goals was to put it on my M925 after I shorten the frame a bit but since the M925 has an engine knock, I wonder if I should find a clean M931 tractor and toss it on that instead. I'd mainly use it for ranch work and would rarely have it on the highway so a winch would be a benefit. Any pros or cons with putting it on either the M925 or M931 (assuming both are running and are in same shape).
I have no idea if I can connect the PTO or have to use a separate hydraulic pump system.
