- 65
- 19
- 8
- El Paso, Colorado
I bought 4 LED lamps for my M35A2 Deuce about 10 years ago, mounted them about 6-7 years ago, but didn't get to enjoy them at the time, because of a bad turn signal switch, then a failed flasher unit.
Some kind soul on SS posted plans for a build your own electronic flasher, which I did successfully. Cheap too! Oh, I was in hog heaven for a while, having 100% of my lights working, until this winter.
One cold day not long ago, I noticed the bulb on the turn signal switch was brighter in one direction, than it was in the other. When I checked the outside lamps, I noticed that the right rear lamp wasn't lighting fully, and that was the side with the brighter feedback.
Then, after leaving work last night in my daily driver Deuce, I saw that I had no right rear lamp at all. Today, when it warmed up, it was working again.
The pictures show what happens in the front when I activate the turn signals in either direction. The top pic is lamp flash off, and the lower pic is lamp flash on.
My question to the brains and those experienced with military LED's is this....are there parts inside that can be diagnosed and repaired by someone with circuit knowledge?
Air temperature seems to be a HUGE factor in working or not.
If I'm unable to get these things to work reliably, I'll probably have to go back to incandescents.
Little help?!?
Little help?!?
