Air assist issues
TechnoWeenie
1,655
Nova Laboratories, WA
I'm having some issues with air assist, and I'd like a second opinion.
I can turn the wheel right, and I'll have full assist.
If I turn the wheel LEFT, I not only have no assist, I feel like I'm having to fight the steering wheel to go back to center, like it wants to stay right.
Thoughts?
TechnoWeenie
1,655
davidb56
1,237
Bonners Ferry Idaho
Id pull it off and soak it in something that won't harm the seals, but has lubrication/penetration (sounds porno) qualities like diesel fuel or transmission fluid. maybe immersed in a bucket for a few days. It wouldn't hurt it any more since you are looking at buying a new one anyways.
TechnoWeenie
1,655
Sounds like a plan. When it's not 110* outside, I'll get on that ;)
glcaines
2,410
Hiawassee, Georgia
Seems I read somewhere to use air tool oil throughout the system once in a while.
Please let us know how this works if you try it.
Thanks
When I first got my M35A3 10 years ago I had some similar issues. I jacked the truck off the ground where I could easily turn the steering wheel to left and right lock repeatedly very easily. I then added air tool oil to the air line, probably a teaspoon full, hooked the airline back up and turned the wheel from lock to lock about 20 times. I then repeated the process a few more times. It fixed my problem and now 10 years later I still don't have any problems. I can't take credit for this as someone else posted this process and I just followed the directions. One note is that I have not added any air tool oil to the system since the original fix, but perhaps I should.
davidb56
1,237
Bonners Ferry Idaho
When I first got my M35A3 10 years ago I had some similar issues. I jacked the truck off the ground where I could easily turn the steering wheel to leaft and right lock repeatedly very easily. I then added air tool oil to the air line, probably a teaspoon full, hooked the airline back up and turned the wheel from lock to lock about 20 times. I then repeated the process a few more times. It fixed my problem and now 10 years later I still don't have any problems. I can't take credit for this as someone else posted this process and I just followed the directions. One note is that I have not added any air tool oil to the system since the original fix, but perhaps I should.
thats a great idea. I dont have air assist, so my steering never wants to turn in either direction. hahahaha
