290smallcam
- 36
- 28
- peru,indiana
At what point would the T 136 case come apart? Can't find the max tourqe ratting for it here or any other sites. Would 600 ft two be way to much?
When I get back I'll be installing power steering. I didn't find a thicker flywheel yet but I think I may be able to use a dual disk clutch instead.That was my next question, is the transmission as strong. Guess not. I'm always watching jeepsinkers YouTube videos when I'm board. Love to see him do a power steering hf54 conversion. By the way if jeepsinkers reads this, did you ever find a thicker flywheel? I know in your video you wasn't pleased with how far you input shaft went in.
Well, our transmission actually does act like a torque multiplier for the engine. So, for the 3053 in 1st gear, at 5:1 - the transfer should hold all day long at 2000 ft-lb, at least. I know it does - and much more than that.Not sure about torque but it can handle 200 hp at 2800 rpm all day.
A #2 bell for the 3052/3053s? Not that I know of... (?)instead of using a SAE#2 to SAE#3 adapter ring, is there a SAE#2 clutch housing that will fit the spicer 3053?![]()
Sure, with the right clutch and an SAE2 bellhousing.The pilot bearing would be the same I think. The Spicer 6000 series was used on the LDS in the 5 tons. So I think a 6352 input shaft would fit the 6BT?
Same as what? Not the same, if you are referring to the 5-ton Spicer vs. the Deuce's 3053.The pilot bearing would be the same I think. .....
Can confirm for sure. I'm just finding this out the hard way. I got a LDS motor, but it looks like they put a LDT crank in at some point because it has the .750 id bronze bushing instead of the 30mm id bearing listed for the 5 ton. I always thought the motors used the same crank. I was apparently wrong.Same as what? Not the same, if you are referring to the 5-ton Spicer vs. the Deuce's 3053.
It probably has a bushing adapter pressed into the crank. While I'm not 100% positive, I don't think they would've had a separate crank for 5 ton and 2.5 ton applications. Bushing/ bearing adapters in crankshafts are very common.Can confirm for sure. I'm just finding this out the hard way. I got a LDS motor, but it looks like they put a LDT crank in at some point because it has the .750 id bronze bushing instead of the 30mm id bearing listed for the 5 ton. I always thought the motors used the same crank. I was apparently wrong.
They sure didn't make drivetrain modifications easy on these things. Now I get to choose between machining the fso6406 input shaft down, or making a contraption to bolt to the clutch housing so I can fire the engine up, feed a cutter in, and bore out the crank, or, making a flywheel spacer and clutch housing spacer/adapter.
The FSO was only available with SAE#2 clutch housings and pull clutches apparently, so figuring out how to convert all that is my next hurdle. It's probably simpler than it looks, but no one lists measurements of anything anywhere, so I can't do anything until I've gathered all of the parts. Just have to find a clutch housing next, or decide to modify/adapt the one off the 3053.
I did more research after this post and it looks like a 62mm od bearing gets pushed into the flywheel on 5 ton applications, which is cool. Now I just need to find a bellhousing and figure out if the 5 ton release bearing setup will work.It probably has a bushing adapter pressed into the crank. While I'm not 100% positive, I don't think they would've had a separate crank for 5 ton and 2.5 ton applications. Bushing/ bearing adapters in crankshafts are very common.
