M1152 400 Amp Alternator
aslemmer
13
California
My M1152 has an issue with the giant 400 amp alternator rubbing on the wiring harness coming out of the firewall right behind it. Two wires have already had to be repaired as a result of this.
Is there any known fix for this issue? There is not enough clearance to guarantee the alternator will not rub in the future.
Thanks for any help.
Adam
Milcommoguy
2,384
Rosamond, CA
Adam
Just what everyone needs. A 400 amp arc welded on a 150 HP engine.
Ahh, Just making sparks, CAMO
AAVP7
263
Dortmund, Germany
Also, a 400 A alternator robs a lot of engine power. Rough calculation: 400 A times 24 Volts divided by efficency of alternator (say: 0.8 ) = 12 kilowatt, or 17 horsepower !
frank8003
4,988
Ft. Lauderdale, Florida
That is sort of a special truck? If She were mine I would protect Her as built and use it.
Check over the whole bracket and mountings....
I to old to have one but already thinkin of ways to power my house with it.
Coug
4,657
Olympia/WA
That should only be when it's actually producing power to that load.
The rest of the time it's just robbing the power needed to keep it spinning, plus a little more for the extra mass/electronics.
If nothing else though, you're going to go through belts a lot faster with it, especially if you like revving the motor.
AAVP7
263
Dortmund, Germany
That´s right. An electronic alternator will adapt the output power, and thus the power it needs as input. However, I recently learned from a Niehoff engineer that their alternators "like to have a minimum load". I think they quoted 25 % of max output, but that´s from memory.
GMVguy
94
Texas
Having the same issue with the main harness rubbing on the back of the 400A alternator on a REV truck. Did you find a good mod to prevent this? If not, I';; just add a wire clamp.
Retiredwarhorses
4,532
Brentwood, Calif
that’s the engine harness, that’s not an issue with 400’s, something else cut that wire or the harness was run incorrectly.
This 400amp issue has been beaten to death On this forum by yours truly, I even fabricated the first conversion to 200amp generator using the
400amp bracket. Since than, I no longer replace the 400 unless it just flat out fails.
There are two types of trucks with the 400amp, one is a factory truck, and one is a truck that had the 400 installed as part of an MWO, I’ve found the trucks that were MWO’d had the issue or trucks that went through a full reset.
The problem was the angle the body harness took when exiting the firewall on the driver footwell, this “angle” as i will call it, can’t be changed once the harness is laid in during production. For MWO trucks, you used the provided split loom and tie wraps on the body harness to prevent chafing of the harness, and I must say, not too successfully, the generator fan shroud and vibration would easily cut through the split loom and the harness wrapping, the wires commonly affected were the front light harness branch and if on the main branch, it would be the TPS “throttle position senor” wires, as they are in the harness on the outside of the bundle, I’ve personally and successfully repaired numerous non-shifting trucks here in the shop. I have also started putting about a 3in piece of edge guard on the cooling fan shroud on the generator.
Anyone who buys a turbo truck can immediately perform a check from underneath, this pic I’ve attached is an offending generator and this truck is experiencing shifting issues that can’t be explained…till now, this scenario plays out monthly.
I don’t see this issue on factory trucks, the harness in most cases is an inch or more separation from contacting the rear cooling shroud.
