The turbo will not add a ton of HP. I believe a 6.2 is rated 160HP or 185HP for the military version. Not sure where those 25HPs would've come from? Only difference is the EGR valve. I don't believe the EGR robs the engine of that much power? A 6.5 TD is rated at 215 HP from the factory.
These trucks are build with heavy duty parts. The transmission, transfer case axles/differentials will handle the added power from a turbo just fine. The parts on our trucks are sought after by many with high HP builds or extreme off-roading.
Overheating is supposed to be a big problem on 6.2's and 6.5's. Especially on the back 2 cylinders. The best cooling upgrades you can do is use a 99+ waterpump (better balanced flow), a heavy duty (Hayden) fan clutch and Duramax fan (more blades, larger diameter and better design. Flows way more air). The 99+ waterpump and Duremax fan will require a serpentine belt drive system. The V-belt system rotates clockwise and the serpentine rotates counterclockwise. If you want to stick with the V-belt system you can get an early HMMWV fan. It will flow more air compared to the stock 6.2 or 6.5 fan. Actually, I have one laying around. It was supposed to go on my friend's truck, but after ordering we decided to swap the V-belt system for serpentine belt. I believe they are a pretty rare find nowadays.
There's a guy over at The Truck Stop forums who sells new waterpumps cast by AMG (P400 pumps?). I bought 2 from him.
I was not aware of the overheating problem. So far I haven't been to a forum or need any other information about the truck. Before it was put into storage, it ran like clockwork despite the now obvious damage. Never had a failure of overheating also not with trailer - but the Chevy is in germany only on 3,5 to trailer authorized. More trailer load would result in an annual technical inspection for road authorization (with 3.5 tons the usual biennial inspection remains) and a tachograph. As i don`t need more load....
There is no build in on special parts - all is just original like bought 1996 except the cooler. Cooler was leak after 15 years storage.
So i should looking for the GEP6500 Optimizer and if still got not better waterpump and Fan should this be changed.
I am still unsure of turbo
What i have seen is, that the 6,5 turbo used is on offer, the NA ? as Optimizer not the first ones ? didnt see it until now
The descision will be there if we got an offer for a good used one
It could be also closely with the big batterys in use.
We needed new Batterys and as there is space enough we choosed the varta which are not same dimension like original. So need a bit more space... and of course new mountings. Don`t mind the resistor on the aircleaner. It was a picture taken of one from severals test during search on the electrical failure of generator 2 (for info: it was a sticky alternator carbon in a new alternator with a new switch... - now we learned of it and testing new parts before build in)
Next question going the stanadyne DB2 under overhaul or give him the DS4 - if using DS4 what need it more changing.... are there other options?
I have also contact technical office for Road authorization as using other engine it is already necessary to got that verification. That means i need papers from manufactores who said i can use exactly that engine with the listed specifications ( for example 6,5 GEP Turbo) in that old truck maybe by changing subsystems usually breaksystem - what i already not expecting. Needed to do on our volvo 945 as 16V engine only with ABS and the 945GL =
Ganz
 leer german slang translation => Complete empty meaning out of any accessories or special equipment. So we needed also the breaksystem from the 16V and some other parts. So we changed in the past not only the engine. I got a long list from volvo which i had to change from Car A to Car B and for this the wanted both VIN. At the time, that was a case-by-case decision and the document cost accordingly.
With such a paper from manufactor is it not a problem, without very expensive as the car  has to going under several test, maybe you have comparable tests and studies, otherwise usually unaffordable for private users.  The NA ist specified as exchange Engine with original IP DB2, there should it be no problem on it.
For example i can be sure that using the 6,5 Turbo will prevent the history approval in germany. Or was on any time used in the M1008 ever a turbo engine?
