- 472
- 357
- 63
- California
Good News! I am sharing all these details in case someone else will ever run into these issues, which will save time (I am not sending you to read the manual
...but it is useful in the longer run)
I removed the air cleaner canister since I was going to replace it because it is missing the bottom rubber boot (it is totally ripped) and in the process I was able to get behind the AC compressor and replace the last leaky return fuel line...without having to loosen the serpentine belt and/ or remove the compressor!
![ReturnFuel2.jpg ReturnFuel2.jpg](https://www.steelsoldiers.com/data/attachments/608/608605-322837d6ee95d050c45a4b687f583173.jpg)
The air horn doesn't look too bad,,,there is some minimal oil inside, from the missing CDR valve line:
![AirHorn3.jpg AirHorn3.jpg](https://www.steelsoldiers.com/data/attachments/608/608607-74e96f072330f558a8e8759de83d63e3.jpg)
