Hi guys I´m back with another problem.
Today I tinkered with my electric a bit since somebody cut and rewired my light switch connector.
Long story short, I told my girlfriend to step on the brake pedal so I could watch the back brake lights. She stepped on it pretty hard and when she released it,
all primary air dumped out and the air warning buzzer came on.
So what could have happened?
When I shut off the primary tank on the wet tank the secondary builds air fine.
Condition as follows ( primary side closed on wet tank, secondary tank full )
- Secondary pressure stayes the same wether I open the parkingbrake or not.
- Secondary pressure stayes the same when I put in the spring brake override.
- Secondary pressure stayes the same wether I use the parking brake or the spring brake override.
When I shut the truck off secondary holds air.
As soon as I open the shutoff valve on the wet tank to the primary side I can hear air in the stack and the horn like sound it makes when you step on the brake till the wet tank is empty.
Where should I start looking for the problem?
Thanks in advance guys
