CivilEGR
- 24
- 8
- Detroit, MI
I had to send my truck to the shop when the transmission decided not to go into drive/reverse.  They dropped the pan and and found out pretty quickly with all the metal that I needed a rebuild.  I also had them do a few other small fixes that I didn't want to deal with myself and that completely blew my budget for my toys for 2022.  I just got a call back from the shop saying they went for a test drive with the rebuilt transmission and it was shifting late and hard.  They took it back in and checked the vacuum and found the pump was bad.  They figured the pump being bad likely also contributed to the transmission failing.  Now they're looking for around another $1K to replace the pump, lines, modulator.  I really don't want to put another $1K into this.  I had a pump from an old engine I could use, but my question is, can I replace the pump myself with the engine still in the truck?  Or does the who top end need to be disassmbled and pulled?
		 .  I just did all this myself, and with a really bad back and not great mechanical skills.  With your new trans, after you do the above, she should run like new, mine did.  And final adjustment is easy.  Like Rick always says, "You can do this".
