Tale of two Deuces
Rhino 5/4
1,868
Waco, Tx
Not sure if link works but our bonding last night worked out. A little foreplay and she purs nicely. Guess someone twisted off the radiator drain "valve" (trying to keep it pg)and she pees as fast as she drinks. Going to parts yard to see about a radiator along with some other parts tomorrow. Wasn't all hugs and kisses though. Forgot we robbed the throttle return spring and first crank up was a little scary, shredded both generator belts and didn't see pump not spinning. Poked a hole in a fin putting on a belt and added to the water fountain. But....she runs and move.
ToddJK
4,490
Sparta, MI
The links worked. Glad to see it running! That's one step closer to being completed!!
ToddJK
4,490
Sparta, MI
Nice score today!
It’s like you found the green iron Walmart!
Sometimes just cruising around and checking out what's in the area can pay off. I was cruising around some old stomping grounds and took a detour due to road construction. I found a deuce in the front yard that doesn't look like it has moved in a long time with tons of tires and parts in the back. I was thinking of stopping by and see if the owner is interested in selling anything. Could be a diamond in the ruff and not even know it 🤷
Rhino 5/4
1,868
Waco, Tx
Yes for sure. Spare parts are always a good thing.
Rhino 5/4
1,868
Waco, Tx
Happy Father's day to everyone. So we worked on the 109 today and got rid of the board and bucket me and my grandsons have been riding on and installed the spring seat and bench we procured yesterday. I must say that foam and bouncy is a little easier on the arse than a 2x10 with splinters and nails
But some girls like it rough and sometimes we just have to sacrifice hehehe. Looks like she spent a little time in Germany. Found this coin in a corner when I was cleaning out the rat and coon crap. 20220619_165422.jpg20220619_152747.jpg
19,161
Pickin the boys up tomorrow so between dips in the swimming trough to cool off, hoping to get radiator swapped and brakes blead on the M35. Assembled my milspec power bleeder today to assist in the process.
Good Deal @Rhino 5/4 ! The little guys should have another great adventure! That really is cool that you guys get to have that fun.
Hey, bleeders "ain't pretty" but the one that I built years ago works really well! Nothing like being able to do it as a one man job too...
Picture below is very similar to the Wagner we had at RH Bouligny. The split in the middle was where the rubber bladder separated the brake fluid from the air. I was really impressed when I used a bleeder for the first time!
