Tires
SCSG-G4
PSVB 3003
5,399
3,490
Lexington, South Carolina
DUKW tires have a higher ply than the Goat tires, but originally were made to be deflated to 15 psi for going over sand beaches, then pumped up from the cab back to 50 psi for highway use. I have no idea what the specs are for the Coker tires
m561gamagoat
30
Akron/Ohio
Im aware. The Goat tires are 6 ply but those available arent usually very good with dry rot. I currently have 10 extras all questionable. Thats why I haul two around with me!!
G744
4,089
Hidden Valley, Az
A note about Goodyear Goat tires, they are steel-belted bias ply tires.
Unlike just about any other tire out there.
DG
SgtMajHarper
618
Falcon, CO
Coker Tires in Chattanooga, TN sells DUKW/Goat tires, check with them to see if they can recommend something. Didn't the Goat have tubeless tires? if so, you may be looking for a unicorn!
Yup, the Goat tires are tubeless.....that's how I run mine, I know some guys run tubes tho. bet they will chime in on here eventually. (Maybe the tubes help them float better)?
combat32
107
Booneville AR.
Problem is getting my nos tires expanded enough to seal on the rim. Even though they are new the sidewalls are collapsed down from being stacked for decades. Maybe after I run them for a while they will resume their former shape and I could go back tubeless
SgtMajHarper
618
Falcon, CO
Same thing happened when they mounted my new tires. They left them out in the warm sun with a tube inside (not mounted) and they came back into shape so they would seal. They have been holding air fine since mounted and tubeless.
combat32
107
Booneville AR.
I don't think DUKW was tubeless, should be same size, just having a hard time finding 1100.18 tubes, seem to be extinct, would a 900.20 do for a while I wonder?
