RoccoM1123
- 6
- 3
- NJ
2003 M1123 what replacement wheels and tires fit?
It appears that 17” x 9.5” is the right size, however there are a lot of other numbers when you go to buy them. For example there is the offset, bolt pattern, center bore and backspacing.
i found these wheels from black rhino “armory”that are described as follows;
17”x9.5”
8 x 170mm bolt pattern
-18mm offset
125.1mm center bore
4.54” back spacing
will these fit???
Also, what tires would you recommend? Size and brand?
Thanks!
17”x9.5”
-18mm offset
125.1mm center bore
4.54” back spacing
will these fit???
Thanks!
