MEP-803A Alternator and Pulley
Farmitall
276
Eubank, KY
Ok, got the alternator on and bolted up.
Needed a slightly longer belt. Got a 4040365, but a 4040360 would've been better. 1/2" bottom bolt with grade 8 washers for spacing. 8 groove HD truck pulley. Everything seems to like up.
Now it's time to connect the wiring. I have four wires that look like they were connected to the old alternator. Any way to trace what goes where? Battery, exciter, ground and ?
View attachment 900997View attachment 900998
Yes, the schematic.
CaryHenry
Columbus, IN
Thank you! The struggle I have is the wires on my gen don't seem to be labeled, so I'm assuming some probing is in order. Ground is fairly straight forward. Regarding the two connections on the bat terminal, if I have batteries and back probe those, should I see power when the system is off. Similarly, for the exc, I'm assuming I should only see power when the switch is set to run?
