M10A International Harvester Rough Terrain Forklift
Threedoor
10
Lewiston, ID
My hunt for parts and information has taken a year.
the 530 bucket cylinder is different from the M10A
M10A from center of pin to end of cylinder measures 29”
530 loader measures 34.5”
The hoses appear to be long enough on the forklift to work with the longer stroke cylinder.
I haven’t come up with a bucket link/dog bone but got a measurement off of one from Vanderhaggs.
Center to center 26”
SergioServin
East Texas
Quick updates.
I replaced the air compressor with a newly rebuilt one and that unit ended up having an oil leak.. so i traded an internal leak for an external leak. :mad: It had a 1 year warranty so I swapped it out and am insanely quick at the process now. If only other M-series trucks were this easy.
The rear drive shaft that was removed had been squished and had impacted splines. It didn't need to be dropped since they removed the parking brake pin but ugh.. it is what it is. I sent it off to get retubed, new u-joint to be safe, and reinstalled it. A few electrical gremlins have surfaced but were very minor: fuel gauge pegged out (since self corrected), oil pressure gauge doesn't rest at 0 when off but works when on, and some exterior lights don't work. I'll be swapping the lights out with the 7" route clearance lights eventually. Otherwise she's mechanically sound and been earning her keep.
Good morning, I recently bought one of these units. Got a real good deal but it does not have the air compressor. I was wondering if you could help me with the part number for it so I can find it. I've searched the web and just cannot find anything. I found one that looks similar but I am not sure if it will be the one. Can you help me out please. Just need the part number to the air compressor.
fuzzytoaster
3,683
Fort Worth, Texas
TM P/N: 277056 which translates to the following: KN86020, 1298894H91, 1655043, 277056, 280688C91, 5106141, 5131511, 5145614, 4310-00-778-8072, 00-778-8072, 4310007788072, 007788072
KN86020 is the most recent number and the cheapest I found by quick search is below.
SergioServin
East Texas
Thank you Sir, I've placed my order from the link you provided. Hope to have this thing running soon.
SergioServin
East Texas
Quick updates.
Hey Boss, could you do me a favor and upload some up close pictures of the lines and where they go. My problem is I purchased this machine without the compressor. I see some of the same characteristics on yours but I did not find all of the lines yours has going to it. I've searched and searched and cannot find any pictures online. Can you please help me out.
Thanks!
fuzzytoaster
3,683
Fort Worth, Texas
Thanks!
TM 10-3930-643-24P has all your answers ;)
Threedoor
10
Lewiston, ID
Recently the water pump went out on my M10.
they are NOT the same as the international truck or bulldozer. The shaft is 6” long and smaller diameter whereas the truck one is has about 2 1/2” long shaft.
Gates does not have one.
international truck shop can’t look it up.
International ag shop found a picture of it and their part number was the same as the truck one.
I found some
PN 690668 C93
NSN 4320-01-089-4263
These guys have a few. I ordered two and offered them $500 each for them which they accepted on their eBay store. https://getexcess.com/products/cent...0894263-690668c91?_pos=2&_sid=20fdba954&_ss=r
Threedoor
10
Lewiston, ID
Thanks!
Looks like the pump on my 90s vintage international truck.
Threedoor
10
Lewiston, ID
I found some
PN 690668 C93
mom the left is the M10 pump, right truck and dozer DT series engine pump.
Mark Buller
12
Darlowo, Poland
I've got 3 of them and I love them! NEVER will I be without at least ONE. All so far (since 3years) work reliabily and problem free. Just a few minor issues like finding (reasonable priced) O-ring seals for the side shift cylinder etc. But ANY big MV Fan/collector with several Trucks/Tanks must have one of these!!! They are as useful and necessary as my Snap-on tools!
byrdman1312
154
Parsons, TN.
They are very rugged and forgiving! It won't hurt it if you "accidently" put 5 gal. of diesel in the hydraulic tank. Don't ask how I know this! It ran for years without any issues. We never tried to take it out. I haven't seen it in two years. As far as I know it's still working fine. The "accident" was about 6 years ago. What a bone head!
dan2002dd
25
ellaville, ga
I just picked up a M10A today. It has a short in the key switch/starting circuit somewhere. I was able to start it by hot wiring the injector pump and the starter and it runs great. I've been going thru the TMs trying to find a wiring diagram to help trace it down but all I have found is the 10-3930-643-20 that walks you thru testing everything. I will do that but was hoping there was a complete wiring diagram somewhere. Can anyone point me to that? Or is something a common problem that I should check?
Guyfang
26,858
Burgkunstadt, Germany
I am sure you can find the info here.
